one of my stoves is an older Lopi Endeavor (came with the house) that has a single wall flue feeding into a class A SS chimney. I've got a flue gas probe thermometer about 18" up the single wall pipe that ranges from 0 - 1700 degrees F. When I run the stove, I had aimed for roughly the mid range of the probe ~ 900-1000 degrees...sometimes when reloading it climbs to 1300 or so then settles back down. Recently I moved the magnetic stove-top thermometer from my other stove to this one and the stove was around 700 degrees...and just stayed there.
I was pretty shocked thinking that was pretty hot. Is that a usual temperature delta between stovetop and flue-gas? According to the Lopi site, 800 is considered overfiring, yet I've got primary air shut off when reloading and it still lights up to 1300. Time to replace gaskets probably. Anyone else monitor their stove with a flue-gas probe thermometer?
