Hi all, I have a problem with a wood burning stove which I hope someone can help me with.
About two years ago I took a small Charnwood stove out of my living room and replaced it with a Broserly Hercules 30 boiler stove.
I had used the Charnwood for a couple of years with great results, and had burned anything and everything in it including mdf with no problems, but as soon as I put in the Hercules I had complaints from one of my neighbours about the smoke and fumes from the stove.
After a couple of weeks of use I stopped burning MDF in the Hercules and for over a year have only burned waste white wood like scrap pallets etc. but my neighbour still complains bitterly about the emissions from the stove.
The problem seems to be that the boiler stove is much more efficient at taking heat out of the flue gas and as a result the exhausted gas does not get the same secondary burn that it did with the little charnwood.
My neighbour called environmental health out who can't see anything wrong with the stove, but still he is far from happy.
The Hercules is connected to the earthenware flue via about two feet of 3mm mild steel that I had rolled into 8" diameter and welded.
At this stage I'm racking my brain trying to fing a way of cleaning up the flue gas to get it up to the standard it was before and in so doing alleviate any smell.
I would be most grateful for any replies or thoughts whether they are "inside the box" or not!!
Regards
Regards
