stove control itself should be enough unless you have a very tall flue or some sort of external situation that is causing an extremely high draft rate. Once you have a hot fire going ( top of stove about 400
![Fahr ::F ::F](/talk/styles/default/xenforo/smileys/f.png)
) with the control wide open start sliding it in a bit at a time about every 10 minutes or so. Generally around the 1/4 way open will give about the best fire / secondary operation and time length. You will get to a point ( with good dry fuel) that the flames you see are just rolling at the top of the stove no real flames on logs themselves, this is the secondary burn just burning the gas coming off the wood. It will take a bit of experience with your stove to get things down part- several UTube vids of secondaries in action.
Adding a second damper can sometimes cause more problems than it's worth.
also note that even with the control full pushed in there will still be combustion air available to the fire from other intakes. ( glass air wash and secondary combustion air supply which are not controlled by the internal damper on the main air supply.
