Looking to install some floor vents to gets try to increase the amount of heat I get upstairs from my stove. Ceiling above my stove is a drop ceiling. Suggestions?
Do you have a reference for that? Is it the building code, fire code, mechanical code?Before you cut, check with your town hall. This is against code in most cities.
I cut my wood oak floor to put in a register, back then had a woodstove in the basement it was over 100+ degree's down there, it was a 9x13" register and it did NOTHING!!
Unless you can run a fan in it....Dont do it
