Hello all, I have a Englander pellet stove and I need some help on building a hearth pad/floor protection. I will be installing this stove in our living room and I will be using on the really cold days when my Lopi cant keep up. the floor of the living room floor is plywood.
the Manual states that " If the floor is constructed of combustible material such as hardwood, linoleum, or carpet, the you will be required to use floor protection between the unit and the combustible.The protection should be U.L approved or equal, and should be large enough to provide a minimum of one inch (1") behind and four inches (4) on both sides of stove. The clearance in front of the stove should be at least six inches (6). the freestanding pellet unit will need a minimum 31"x 32" floor protector."
I did go into town to ask out building inspectors, but they had no clue what i should build. I was told to call the company. So here I am asking. My plan (1) was to remove carpet, use (2 ) 1/2" sheets durock over the metal studs, and tile. Plan ( 2) was to remove carpet, lay-down Durock and tile. the size of the hearth pad was going to be about 38" wide and 44 long"I just don't know how much floor protection I need for this stove. I know better safe then sorry. But do pellet stoves need a raised hearth pad? thanks for all and any help Fespo
