Anyone have experience installing a floor fan near a woodstove to capture a little radiant heat and send it downward? I have no illusions about capturing much heat from BELOW my stove, but just a little dry air circulating into my basement may help me eliminate some moisture problems (not to mention give me a better temp to age the wine I got working down there). HVAC columnist James Dully offered the following suggestion to someone with a similar scenario, and I'm like to try the application. But before I start cutting holes in my wife's hardwood, I'd like to hear from someone who's tried this. I was really surporised that I could find no past posts on the topic.
From Dully -
Heat energy
from a hot stove radiates in
all directions equally, but
hot air rises as you have
found. Put a return vent through
the floor in one corner of the
room that is seldom used.
Somewhere near the
stove, install a floor fan
to blow the warm air
down into the cellar.
This will force cold air
up the corner vent. By
the time the cold air
reaches people, it will
have mixed with the
warmer air and be comfortable.
From Dully -
Heat energy
Somewhere near the
have mixed with the
