flate plate HX flow direction question
pybyr
2,300
Adamant, VT 05640
I've got a 5x12 70 plate of one of these to use between my boiler and my unpressurized storage
http://www.flatplate.com/pdf/hydronic/FPbrochure9-99.pdf
I want to use valves to maintain counterflow acrross the HX in both modes of "loading" and "unloading" the tank with heat
which is making me realize that I don't see any markings on the HX as to directions of the flow
can someone fill me in?
i.e. if I push fluid in the same physical direction on both sets of fittings, can I assume that that would be "non-counteflow"
I don't want to make some stupid assumption like thinking that I can intuit flow direction from the outside, and have it be llike some situations, such as the relation (or sometimes lack) between the position of a toggle switch's handle and the actual position of the contacts...
thanks!
I am not currently up to speed on your system design, but if you are reversing the flow through the plate hx similar at all to what I did, one of the two directions would not have counterflow. It is a little less efficient transfer without counterflow, but in my application it seems to work fine. Perhaps this isn't an issue with your design. I chose to have counterflow on charging because the temps were going to be closer and harder to transfer heat in the upper end.
