Hi, I'm hoping to get some advice on how to seal up and stop the gas leak found on one connection location under my gas fireplace.
I smelled a faint gas smell which led me to use soapy water on the gas line connectors. One spot generated bubbles, the connection of the gas line into the metal housing under the fireplace. See attached image as I'm sure I'm describing this poorly. The leak isn't at a simple bolt to screw connection but seems to be at the connection of the threads to the metal housing which is surrounded by a yellowish caulk/sealant.
One image shows a red arrow indicating the leak source. The other two are zoomed out to show the fireplace setup for reference.
Do I need to apply more caulk/sealant or something similar around the seal? Would I need to disassemble anything?
![Fixing Small Leak in Gas Line Connection Fixing Small Leak in Gas Line Connection](https://www.hearth.com/talk/data/attachments/270/270712-287f37ed4cfe6aaf696d54b5007b02a4.jpg)
![Fixing Small Leak in Gas Line Connection Fixing Small Leak in Gas Line Connection](https://www.hearth.com/talk/data/attachments/270/270710-816eadd9ebda7f14378f12dcbb787bf1.jpg)
![Fixing Small Leak in Gas Line Connection Fixing Small Leak in Gas Line Connection](https://www.hearth.com/talk/data/attachments/270/270711-725eeb3ae58046e54a10b1f55314f8e4.jpg)
