Hey guys, I'm finishing up an in floor hydronic setup. All tubing is in. I'm running the Takagi LP tankless https://www.supplyhouse.com/Takagi-...ss-High-Efficiency-Condensing-Water-Heater-LP
There are will be 2 zones (at first) with this manifold
https://www.amazon.com/dp/B011W5KDGM/?tag=hearthamazon-20
I still need:
Circulator pump
zone control valve
zone controler
thermostats
I'm reading lots of good things about the Taco products. Should I go with the Delta T variable speed circulator and a zone valve, or 2 seperate single speed circulators??
Anything else you guys can think of??? Any input would be greatly appreciated thanks!!
also, can I run any thermostat?
(this is my first hydronic build)![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
EDIT: I just read this from the manual: "*The recirculation pump is to be controlled by: -Dual-set aquastat (recommended w/timer) *The recirculation pump is to provide no less than 2 GPM (7.5 L/min) and no more than 4 GPM (15 L/min) through each activated unit in the system."
I still need:
Circulator pump
zone control valve
zone controler
thermostats
