Wood Fuel FIVE ESSENTIALS TO GETTING THE MOST OUT OF YOUR WOODPILE
webfish
Hearth.com LLC
Staff member
1,833
Minnesota
By Ike Johnson , reprinted from Back Home Magazine with permission
Cut Ahead and Burn Dry
Keep it Dry !
Burn Efficiently
Keep the Heat In
Burn the Best
There are several reasons for choosing wood heat over the few available alternatives. Not the least of these reasons is economy. In New England where I live, for instance, 11.4 per kilowatt electric rates can give your mortgage a run for its money if you’re unfortunate enough to have electric heat. Wood burning boasts advantages other fuels can’t mimic: an evenness, quietness, and aesthetic appeal truly unique to wood. There are many who relish the rituals of self sufficiency involved with getting in their own wood. That’s not to say that more is necessarily better. No matter how much you admire the sight of a cut and split stack drying in the autumn air, you owe it to yourself to get by with as short a stack as is prudent for the winter in your locale. Here, then, are five strategies for milking the most Btu’s out of every stick you burn.
Green wood contains up to 50 percent of its weight in water. The first stage of combustion involves bringing this mass of water up to its vaporization point. The energy expended in doing this does not heat your home. And, while steam heat has its place, that place is definitely not in your woodstove. Worse yet, green wood gives off far more creosote than seasoned fuel, which further robs a stove and chimney of efficiency. On top of that, creosote produces the hazard of chimney fires, which have laid many a home to ash. Therefore, by cutting firewood a full year or more in advance, you theoretically could halve the amount of wood required to heat your home. Buying or cutting two years’ worth of fuel may take some up front money and discipline, but it’ s an investment that pays for itself quickly in dollars, effort, and safety
Keeping the Wood Dry!
Keep It Dry
As obvious as it may seem, let me emphasize that wood cannot dry out beneath a mantle of snow, under a tight fitting tarp, nor pressed three inches into the mud and grass. Many businesses discard used pallets; these can serve as excellent platforms to get each and every precious stick up off the ground where it can dry. Keep stacks of wood separated so that air can flow easily through them. Avoid the temptation to pile row after row end to end, because the wood in the center will not have enough circulation to dry properly. If you have much choice as to where to place a stack, orient it with sun light and prevailing winds working to your advantage. Likewise, avoid if possible over hanging eaves, trees, and structures that can funnel rain onto your fuel. If the stack is against a wall, provide shelter from the dripping roof. Better still, build a woodshed. It would probably take less effort than chasing your windblown tarps after every gale. Here’ s a money saving tip for those who do rely on tarps to protect their woodpile from the elements: use old ragged tarps to cover the newer ones and thus shield them from destructive ultraviolet light. Of course, the best strategy for those who enjoy plenty of room is to get all wood indoors before the rain and snow starts to fly. An attached garage or a basement not only spares the seasoned wood from the elements but spares you those midnight trips outdoors in your nightclothes and galoshes, all the time allowing your firewood to continue drying throughout the winter.
EPA Approved Efficient Stove
Burn Efficiently
Another great energy saving potential lies in upgrading your stove. While the initial outlay is high, you can be certain that the payback from increased efficiency will be seen within a reasonable time. As of 1994 the EPA has required that all woodstoves sold in this country meet emission control standards. The way most stove manufacturers have complied is through the use of catalytic converters, similar to those in a car. But unlike those in automobiles, catalytic converters in stoves make them run more efficiently, as well as discharge fewer pollutants into the atmosphere. A new woodstove with a catalytic converter is rated at nearly 76 percent efficiency. Other stove makers rely on “high tech” designs that are specially insulated and engineered to use airflow and secondary combustion to bring efficiency up and particulate emissions down. These burners typically are compact and not quite the performers that catalytic stoves are, but they’re not as expensive, either. Compare the efficiency of the new models with your current stove and decide whether it’s worth the expense of upgrading. If you’re now using a home built variation of the barrel stove, for example, as much as 75 percent of your fuel could be going up and out of your chimney as dirt and heat. Another robber of fireplace efficiency is a clogging accumulation of ash. On the next warm day, let the fire burn out so you can remove those built up ashes. Also keep in mind that a small vigorous fire is more efficient than a large smoldering one, both in terms of heat output and creosote production.
Keep the Heat In
Naturally, a well insulated home requires less fuel than a poorly insulated one. There is much you can do to control this form of heat loss even after the home is built. You could hire an energy auditor with gadgets galore to come tell you where you are losing heat, or you can try the barefoot test: the next time a cold wind is blowing, take a stroll barefoot around the perimeter of your interior. Your cold feet can provide a valuable input on where heat is escaping.The remedies are beyond the scope of this particular article, but a local hardware store can counsel you on what can be done at what price. It may be as simple as stuffing loose insulation in your attic or as involved as replacing your windows with insulated casements. In any event, try to convert the anticipated cost into cords of wood over the lifespan of the improvement. If you’re trying to talk yourself into a given project, factor in convenience and comfort. If not, leave it on a dollars and cents basis.
Burn the Best
Another way to get the most out of your wood is to be a snob; all trees are not created equal. Go for as good a grade of fuel as possible. Assuming 90 cubic feet of solid wood per cord (and remembering that an actual 128 cubic foot cord has lots of air space in it), dry hickory has 24.8 million Btu of energy compared to a tepid 13 .5 million for dry fir. A neighbor once observed that burning poplar in the “old days” usually resulted in pregnancy, referring, of course, to another popular method of keeping warm on a winter’s night. Nonetheless, his point about poplar being a poor choice heatwise was valid: given the limited amount of time I had to spend on gathering and processing wood, and the limited amount of storage space, the “free” poplar I was splitting was no bargain. Ask various wood suppliers what kinds of wood they offer (see the heat comparison chart) and in what proportion. Insist on a standard unit of measurement. Face cords, ricks, racks, and tons are all in use, but for comparison use true 4’ x 4’ x 8’ ( 128 cubic foot) cords. Determine what is meant by “seasoned.” The dealer may mean a single season (i.e., one winter; not much drying time there) or a full year, which is a decent period for split wood to cure to its full potential. Also, consider the characteristics of the wood in regard to cutting and splitting. The same neighbor with his poplar observation claimed that a cord of elm would last half a lifetime. By then, he maintained, you’d have given up on ever getting it split. These recommendations are not speculative. In the nine winters we have spent in our home, we have pared down our wood usage from a whopping 6.5 cords to precisely 4. The mess stays down in the basement, and the house is much more comfortable than it was in the old days. The benefits are tangible and real . . . in dollars, comfort, trips to the chiropractor, and wear and tear on the saw. And best of all, our savings no longer leave the house via the chimney.
Reactions: yuryk and cstrom5
