I usually use an Englander 30 EPA stove rated at about 2400 sqft in my basement. I used to have an older grandma bear that I fixed up a little, I even hooked it up and ran it a couple times in the spring. I eventually sold it and found another grandma bear “wide body” that I fixed up a little.
About a week ago I hooked up the new Grandma and it works great. It puts out at least twice the heat my englander does even with the blower on high.
I’m wondering why is the Fisher rated for 1500 sqft and the Englander rated for 2400 yet the Fisher way outperforms in real heat output. Both stoves are being fed seasoned oak, good secondaries on the 30 using a moisture meter.
Also as expected the fisher usually smokes a little, goes through more wood, and doesn’t last as long. It also doesn’t have a baffle plate.
Are all epa tube stoves poor at radiating heat or just the 30?![Fisher vs EPA Fisher vs EPA](https://www.hearth.com/talk/data/attachments/257/257218-ab6c2b641ffb6c5b14e8a654b0bca461.jpg)
