It's been a heckuva week. I am on my 2nd used woodburning stove this week. When I got the first one home, a Blaze King, I discovered that I was duped by the seller. It was total junk inside, and I didn't know it until learning more about the stove here.
I just purchased a Fisher medium sized stove. As you can see in the photo's, it has 2 glass doors and an 8" topside flue. Inside, the firebrick is missing around the sides. I will replace those tomorrow.
Question 1: What model is this? It's not the largest, so I'm thinking it's the Grandma stove???
Question 2: The door has no gaskets on it. Is this normal, and if not, what gasket size should I put on it? The local store has 5/8" gasket for doors.....will this be sufficient?
Question 3: There is an internal baffle, as shown in the pictures. It doesn't stick out really far from the back, and maybe just barely extends beyond the 8" flue exit. Is this sufficient to make this stove create heat?
I'm using this to heat my 1700 square foot shop w/ 12' ceilings, fully insulated. I have just installed brand new 8" chimney, schedule A insulated DuraVent 8" SS pipe and 8" black solid/welded stove pipe (Ventus?). It is a straight shot up through the attic space and roof, and is done properly. It made the other stove draw very well.
Question: Do I need to install a dampener inside the black stove pipe, or will the two dampeners on the sides of the stove be sufficient to control the fire.
I know this is a lot, but I'm a mess right now trying to get heat for my shop. I work in there full time, and have been using a radiant heat driven by propane for 12 years. Just recently, the propane shortage drove the price from $2.19 a lb. to $6.79 a lb., causing my monthly heat bill to go over $1000.00. Now, I can't even get propane delivered.
Thanks for any help.
Jeff![Fisher stove questions from a newbie Fisher stove questions from a newbie](https://www.hearth.com/talk/data/attachments/127/127480-a611ebe55c0356c36f23f5c1baa69355.jpg)
![Fisher stove questions from a newbie Fisher stove questions from a newbie](https://www.hearth.com/talk/data/attachments/127/127481-478347180bb7266f1493c073eeac2b33.jpg)
![Fisher stove questions from a newbie Fisher stove questions from a newbie](https://www.hearth.com/talk/data/attachments/127/127482-12e70d17349e196c6859f1dbfc1393c2.jpg)
![Fisher stove questions from a newbie Fisher stove questions from a newbie](https://www.hearth.com/talk/data/attachments/127/127483-af57ea70d085fb3cc8f04bbc56ec8f9e.jpg)
![Fisher stove questions from a newbie Fisher stove questions from a newbie](https://www.hearth.com/talk/data/attachments/127/127484-83ad91f193858ddf298dcdf69fdd001c.jpg)
![Fisher stove questions from a newbie Fisher stove questions from a newbie](https://www.hearth.com/talk/data/attachments/127/127485-21724f108291125966cb8509cf950ea2.jpg)
![Fisher stove questions from a newbie Fisher stove questions from a newbie](https://www.hearth.com/talk/data/attachments/127/127486-972c2e2e137a38a747c164092f726e87.jpg)
![Fisher stove questions from a newbie Fisher stove questions from a newbie](https://www.hearth.com/talk/data/attachments/127/127487-c86dbad4e2662b1b56068c513ed8274f.jpg)
Jeff
