this is for sale on the local CL, at least the door is a Fisher. Ad states:
FISHER WOOD STOVE OR FURNACE
thanks for any info.
Thanks coaly! It is the old flat top door , no nickel plate but the aluminum knobs in front were painted over and I’m planning to refinish and repaint the whole mama . pics are before restore full restore pics too come.You're describing a Series VI by the shields. (if they are integral with the box and not bolted on) Rear shown below;
View attachment 229904 There are other models with shields, with the older flat top door making it a Series II, so I really need more information.
That model shown (VI) was UL Listed and should have a UL tag on the rear shield, or at least rivet holes where the tag was. That model would have an arched door at top, bent corners without angle iron on the corners that becomes the legs at bottom. They were available with black door, nickel or brass plate. Many were painted over, so if you have an arched style door at top and it is all black, wipe the raised portion around the edge with lacquer thinner or metal polish to see if it is a plated door before using anything abrasive on it if it needs refinishing!
And welcome to the Forum!
Ouch, the guy was quick to take the 400 Too. but I plan on using this stove forever so not a big deal, as for the stove not being UL listed I think I read a post from you on another thread that I would just need to install per code and most insurance companies would be ok with it, I plan on using a double walled pipe tee coming out the back and adding that plate baffle before use....is there supposed to be a double course of firebrick along the back of the stove? Lots of questions and I’m sorry I really appreciate all your help I want to get this right the first time. Thanks coaly!It was made in 1978 or '79 and has older style draft caps.
It does not have shields which you were calling double sheet metal on the bottom and single on the back. Shields are sheet metal, the stove body is made of 1/4 inch thick steel plate. It should be all single wall 1/4" steel plate with 5/16" top. I don't see sheet metal or shields on yours.
It is a Series I, only arched top doors after 1980 were plated. It is not a UL listed stove, so 400 is a bit much. But if you can't find any reasonable, I guess that's what you have to pay.
The second picture is a stove I sold with the added baffle. Make one and add it if you're going to use it. You can't go by that picture since that stove only had one course of brick up the sides. The bricks I added on the sides to support the baffle plate are already in yours.
The tag on top of the ash fender was red and warned HOT while in operation. Nothing you don't already know.
Thank you very much for your time and knowledge , I suppose I will need to talk to my building inspector and see what he has to say. Thanks coalyAs far as being legal, it would have been grandfathered in an original installation. Codes change and are updated constantly, such as your state adopting the 9th version of the MA building Code on January 1, 2018. So when you read comments about codes, they are state and sometimes locality specific. There are some states that do not require UL listed appliances and others that also require EPA Certified stoves for emissions. (not yours, yet)
For safety, installed to the NFPA 211 Standard for unlisted stoves is fine. For legality, since your state adopted the International Family of Codes, (IBC) the Mechanical Code governs solid fuel and venting. That Code no longer allows any unlisted appliances to be installed.
