Fisher Grandpa Bear with the "Fisher/Stoves" doors
Thanks for sharing that. It's only the second one like that I've seen. Must have been a foundry with a different mold. This one doesn't have ball feet, and was never highlighted. It's a better picture of it too.
Fisher Grandpa Bear with the "Fisher/Stoves" doors Fisher Grandpa Bear with the "Fisher/Stoves" doors
I just went through all my pics I have saved of Grandpa Bears. I have each model in a file to make it easy comparing and try to name the file with where the stove is as well. Every Grandpa with the large trees also has the stars. (Every Grandma I have with stars has the smaller trees) When the stars were dropped after the first year the double door was made, they looked like this, with smaller trees; (and matched Grandma)
Those two with the two words have been the only ones with the large tree style without stars.
Since the first single door stoves had Fisher -- Stove on the door with a rather large dash on the door, it's odd that they would use the word "STOVES" plural on only that model. Fisher Stoves in a circle became their trademark and was used as the name of many fabricators making the stoves. (that's a bronze belt buckle given to dealers in my avatar) These could have been an advertising model taken to the many trade shows at the time. It would have been the largest model made, and that is what you would want on the sign for your booth or area at a fair or other gathering. Just a guess since it appears not many exist.
Have to wonder if these "FISHER STOVES" doors have the original round casting on the back to match the round door seal rod welded to stove front, or if they have the square notch on back for the common 1 inch flat channel iron welded to stove front.
Here's a Grandma on eBay with the FISHER STOVES doors. Thompson PA
Fisher Grandpa Bear with the "Fisher/Stoves" doors Poor eBay pic;
Fisher Grandpa Bear with the "Fisher/Stoves" doors Lightened up
This Grandma has the early round 1/2 rod door seal (not 1 inch channel iron) and round notch on back or doors to match.
Fisher Grandpa Bear with the "Fisher/Stoves" doors Lightened photo showing door seal.
There has to be a line drawn as to how many stoves one can have.
I think my wife just drew it. :(
Reactions: Wise Ash-burner
