I recently purchased a home that had a 1980 Fisher Fireplace Insert. I used the insert for the first time in November, and although it's my first wood insert or wood stove, I noticed immediately the flames (and heat) going straight up the flue and the smoke coming out of my chimney.
I was lucky to find my way to Hearth.com and this Forum, where I saw pictures of homemade baffles. I went to a local metal fabricator to find a piece of steel 20"x 15" but they were very busy with commercial customers. They sent someone to look with me for 'scraps' and the best we found was this 1/4" 20"x 13" steel tread. I bought it and placed it on two firebricks. It extends about 4" in front of the front end of the 8" flue and is about 3.5" from the top. It is flush against the rear of the insert.
It works great. The insert now uses less wood, puts out more heat, and there is much less smoke from the chimney. Ideally it would be about two inches longer and have the 2" x 3" notches at the corners, but it's fine for now.
Attached is a picture after I had my first chimney cleaning yesterday. They vacuumed out all the ashes.
![Fisher Fireplace Insert Baffle Fisher Fireplace Insert Baffle](https://www.hearth.com/talk/data/attachments/220/220924-66e471d3852ebc1d77b61a3c3d22d1ad.jpg)
![Fisher Fireplace Insert Baffle Fisher Fireplace Insert Baffle](https://www.hearth.com/talk/data/attachments/220/220923-26dbb08da2f6fdbed628111c384a867a.jpg)
