No gasket material is used on any Fisher Stove with solid cast iron doors. There is no clearance space between the door and stove face for gasket material.
Only Glass door models use gasket.
The door seal is the 1 inch channel iron welded on stove front. The doors make contact in 3 places all the way around the doors making it "air tight" as built. You won't find any door seal pictures or information in owners manual.
Most stoves required gasket material and one benefit of buying a Fisher is the lack of the need to maintain the door gasket material. So many people mistakenly added door gasket material to them causing the doors to not close properly.
You could always apply the thinnest gasket material you can find at any hardware store that is the flat type for glass installation. The doors should still close with that type. It comes off a roll like rope sold by the foot. You apply it with Rutland Stove and Gasket Cement. Door gasket material for other stoves is normally round and too thick to allow your doors to close properly.
In your case you could apply the gasket material with a little Elmers glue and close doors to allow to dry in place. Unfortunately it's easier to do this than to try to teach an inspector something. Remove it before use.
If this 'inspector" knew anything about the physical operation of a heating appliance connected to a chimney, he or she would know the rising gasses in the chimney are lighter than outside air which causes a LOW pressure area in chimney, connector pipe and stove. (This is measured as draft) This LOW pressure area is what allows the HIGHER atmospheric air pressure to PUSH INTO the stove intake feeding the fire oxygen.
The chimney is the engine that makes the stove work! So any air leaks at pipe joints or chimney allows cooler outside air INTO flue cooling the flue reducing draft.
A leak in the stove or door seal allows higher pressure indoor air INTO stove making it burn faster.
Smoke doesn't leak OUT, air leaks IN. Crack the doors when in operation and watch the fire rise from air trying to get into chimney to equalize the pressure.
(You can always ask him what kind of seal he requires on a fireplace to prevent CO from leaking in
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
. Your stove also came with a screen for open door operation which indoor air pressure rushes into stove and up chimney preventing smoke and combustion gasses from entering building. It is NOT considered a radiant heater in Fireplace Mode).
My favorite saying is
"Those who can't do, teach. And those who can't teach , inspect".
