So this is the pile I've been scrounging and working from the past few weeks. Most of it was found at the site of an old logging operation and seems to be Eastern White Pine, judging by the trees growing all around the area. I think the few with the craggier bark are some kind of spruce, they have that smell when cut. Those seem to almost all have marks on them from must have been some kind of mechanical limber? Not sure why they left these laying all along the sides, unless they were too small for what they were after. A bunch I passed on since they had ants all through them, but I think that came after they were taken down. The trunks left behind show they took some massive trees when they went through - a couple measured almost four feet in diameter which seems big compared to what's nearby. I also scored a nice straight tree that had come down in a storm and hung up on a stump, so it has been sitting up off the ground for a year or two and seems pretty dry. I think it might be oak? It has very light color and looks like it'll split nice and easy, it cut like a dream compared to the others. So take a look and let me know if you agree with the IDs, especially the oak (if that's what it is)
![First try at wood ID First try at wood ID](https://www.hearth.com/talk/data/attachments/126/126258-1603d49e5deff7d94061591c06478e3c.jpg)
The 32" crosscut wonder . . . as in "I wonder what I was thinking!" Seriously though, it is a lot of fun, for the first couple hours anyway. I'm definitely wanting to build a proper sawbuck, this was slapped together out of scraps and nails and isn't holding up well.
![First try at wood ID First try at wood ID](https://www.hearth.com/talk/data/attachments/126/126259-1c8a26556db1383dd2279e0ab3934359.jpg)
I'm pretty sure most of these are Eastern White Pine, and you can see the tool marks from what I think was a mechanical limber, I'm picturing a bunch of teeth biting into the bark to pull it past cutters that strip the trunk?
These are some the ones I thought were spruce, judging by the bark and the smell when cut
These are from the tree that I thought might be an oak? The wood is very clean and fine grained.
![First try at wood ID First try at wood ID](https://www.hearth.com/talk/data/attachments/126/126262-cd5cc4e307c33f6d0181efed6c2a7b59.jpg)
This was one of a bunch that were laying in a swampy area, and I wasn't sure if it's gonna be worth hauling more out (they're a lot heavier than the others) since it looks like it might be break apart when I try to split it? It almost looks like it's ready to fall apart.
![First try at wood ID First try at wood ID](https://www.hearth.com/talk/data/attachments/126/126263-1026a3adaa78b4f99cbf9d230fb239b2.jpg)
![First try at wood ID First try at wood ID](https://www.hearth.com/talk/data/attachments/126/126260-0f2dff6d1f46849761a42f1a0f46b508.jpg)
![First try at wood ID First try at wood ID](https://www.hearth.com/talk/data/attachments/126/126261-6809c108359c62c5c39c3bfb76c43d34.jpg)
