I had my first chance to split vertical today and am hooked! (still need to find a milk crate though
I was finally able to purchase a Huskee 22 ton splitter this last weekend and used it for the first time today. Up to this point I have been using a splitter on a 3pt hitch on the back of a Farmall 460. Great tractor but is probably the most cold blooded piece of machinery I have ever used.
The Huskee is much quicker on cycle time and will use less gas so over the long run, it will probably pay for itself in fuel savings.
Just a couple of observations. I am not sure why B&S did not put some sort of choke on the motor. The first time I tried to start it I had no luck. I ended up putting a piece of tape over about 75% of the air filter intake to act as a choke. Seemed to work ok. Also I had to use the primer bulb more than what the manual says. I had to pump it 10-12 times and then it would start. I think both of these issues may be better once things warm up, it has been around 30 the last couple of days.
Glad I finally was able to make this purchase. I split about half a cord today and my back feels much better than normal, probably mostly due to splitting vertical.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
