Hello Everybody, first post. Woohoo. I just bought a used Pellet Stove Insert. The company is The Earth Stove. It has a thermostat and a really nice control panel inside of a hinged door on the right surround bezel. It didn't come with any instruction or installation manual. The model says 2001-1. Its a 2007. The guy I bought it from told me it heats 1800sq. Its VERY nice.
My dad called his local wood and pellet stove store and told them my situation. My house is a 1932. It has a fireplace running right up the middle of it. My fireplace is on the first floor in the living room. I also have second floor and a walk up attic. My fireplace was just cleaned and pointed and reflashed and is in great shape. It also has a top hat on it to keep the rain out. My fireplace also has a large trap door dampner on it with a lever sticking out of the front brick. I assume that is called the flue dampner. My fireplace floor has a trap door that opens and there is a clean out on the side of the chimney in the basement. The guy told him I should buy a 10' section of 3" flexpipe and I will be good to go. He said I only have to extend the pipe as high as the second floor
and I will be good to go. I talked to another guy today and he said I have to get an adapter that bolts to the insert itself and that is what I connect the pipe to.
I get a different answer from just about everybody I ask or read about online. My roof is very steep and I would need to hire somebody to walk up to the chimney if the pipe has to be put in from the top. If I could use flex pipe like the guy told my dad I could do it from the inside myself. I just want to do it correctly but I don't want to spend more than I have too. This is just for supplemental heat. My main source of heat is gas fired hot water heaters.
Thanks in advance!
Thanks in advance!
