I have been using the woodstove/fireplace forums for a week or two now I am installing a HS Tarm wood boiler with/for a buddy of mine. The install seems to be going pretty good. I am using a ARGO 6 zone circ. pump controller & a Honeywell T775A staging controller for controls.
My question is what boiler water temperature should I:
1. Kick on the circulator for the main/primary loop?
2. Turn on the fossil fuel boiler?
3. Turn on a alarm or indicator light to tell my buddy that he needs to go check the fire (low temp.)
4. Turn on main heating loop as a dump zone because the temp. is too high.
5. Turn on basement dump zone & high temp. alarm or indicator light upstairs.
???? I might have problem because max on the controller is 220 degrees then it shuts off all loads until it cools down to 220 again.
