first flue cleaning Jotul F 500 eco
Prometeo
640
IT
A bunch of creosote! The difference, with the clean flue I had difficulty lighting the stove, the smoke was reversed, it didn't happen with creosote, but now I can open the door to throw more wood without problems, first smoke came out!
[Hearth.com] first flue cleaning Jotul F 500 eco
I think the next step is to determine why you are not burning clean. Wet wood? Or running too low?
Reactions: Prometeo
Exact, yes it is essential to determine it, both reasons, Surely, wood that is not perfectly seasoned, and many trials, this amount of creosote, it helps me understand that I can't reduce the air too much, and always load the stove to always travel very hot, flue is 30 feet, I have to consider this length, and that the temperature is not greatly reduced along the entire length.
Is that 30 ft flue fully insulated?
it is a single wall tube, which passes into square concrete bricks, surrounded by other bricks, which on 3 sides overlook the. internal walls. The first 8 feet are 45 degrees included, visible, into the lounge and then about 22 feet into the concrete/brick, vertical. In the roof I sealed the single wall pipe very well, do not pass air outside it. In the first hours of fire, with new wood I should assure myself that at the beginning of the vertical section, externally, I should have at least around 100-120 degrees celsius, are sufficient ? I admit in some tests I was also half of these values.
The uninsulated flue is a large part of why the accumulation is happening. The flue gases are cooling down too much and starting to condense in the pipe once they drop below around 105ºC. Put a remote thermometer at the top of the chimney to see what it takes to have the exiting flue gases stay above that temperature.
Reactions: Prometeo
Excellent description and solution. Should be a Sticky.
Reactions: Prometeo
Thank you, another problem I have, before a 45 degree semi-bend, the visible part, in the living room, I have an air leak, with the thermal camera I notice a temperature jump of 10 degrees, there is a colder halo. In that area recently I get 130 degrees Celsius externally, how could I seal it well? I'm also planning to clean the chimney, next time, without having to dismantle a single piece, but recovering the creosote from the stove itself, removing only the baffle.
