Hi All we gave the wood boiler a try this morning, I turned the oil boiler off last night and fired the wood boiler up at about 8AM. Its a Marathon Logwood conventional unit. It heated up fine, the circulator kicked off and I got hot water flowing through the oil boiler (set in series now) and at about 9am we had hot water to shower with, COOL!
But a few things, first it appears the Ammark draft controller isnt working, it never lowered the arm down.
2nd, the temp/pressure gauge on the top of the wood boiler I dont think is reading temp accurately. I have inline temp gauges on the wood boiler output and the input and the output got up to 220 deg and the return was coming back at 215 so the wood boiler should be at least 215 deg I would think, but the temp gauge on the wood boiler was reading 160 max.
3rd - I did get a ghost flow through the first floor heat zone so I do think ill need to change that circulator out for one with an IFC. the 2nd floor didnt appear to get warm.
So, anyone know about these Ammark draft controllers? Can I get a replacement? Can I take it off and clean/test it?
Thanks for the help
~ Phil
Thanks for the help
~ Phil
