I apologize for all of the text for what amounts to "how do I light a fire?". Just wanted to get some discussion on my specific situation.
Backstory: We have a 50+ yr old home that we bought in May. It's 2 levels, sort of built into a hill. Each level has a fireplace. Each fireplace has a separate flue. The flue tiles were in really bad shape when we bought it, so we had them fixed (stainless steel liner for the upstairs fireplace, and a stainless steel tube for the downstairs in preparation for buying a wood stove this year). Note: There is a wood pile in the back corner of the property. Not covered in any way.
First fire: So, we come to last night. It's finally dropping below freezing, and I want to light a fire. I grab 3-4 logs from the wood pile out back (I have no idea how to determine how good wood is), and put 3 inside the upstairs fireplace. I pull and release the flue chain. I jam some fatwood kindling in between them, light the ends of the fatwood, and close the screen (but not the glass doors). The fire gets going, but is not very big... and it was getting a little smokey smelling (nothing visible) in the house. The smoke smell permeated the whole upstairs... and oddly enough it was STRONGER in the downstairs area (by the downstairs fireplace). As this was happening, I read online that if you crack a window in the room where the fire is, it can help the pressure for the flue. So, I did that.
Long story short: The fire never got very raging, it smoked up the house, and I had to open a bunch of windows for 10-15 mins to get the smell out of there.
What am I doing wrong, and how can I figure it out for the next time? Should I get a small batch of really dry firewood (the ridiculously overpriced kind you see at grocery stores) to be sure I have good wood, just for testing purposes? Should I have "primed the flue" by holding up a piece of burning fatwood or newspaper? Should I have started with the window cracked?
Thanks for any input.
Edit: Also of note: I remember the Chimney repair guys off-handedly saying that we had a relatively short chimney (Like I said, it's a 2 story home, so the upstairs chimney isn't much past the roofline). I know that this can effect updraft, but I refuse to believe that a 50yr old home has had a crappy updraft for all that time. Is that even possible? How could I check?
