Hi All,
This is my first post here. I am in the planning stages of installing a new woodburning (open hearth) fireplace in our home. I will be installing/framing the fireplace myself as well as assembly/installing the chimney pipe.
First a little background:
My wife really wants a fireplace in our house. It was one of the concessions we made when purchased this home 5yrs ago. Our previous house had a decorative wood-burner that we used quite often for extra ambiance in the winter months. So the purpose of this new fireplace is purely for ambiance and aesthetics. We have a furnace & central air for our actual heating needs, so efficiency is obviously not a concern (Hence the open hearth).
For budget and design purposes we will be going with a factory built pre-fabbed unit. We are still deciding between the 36in Majestic Sovereign or the 36in Majestic Biltmore fireplace, but it will be one of these two most likely.
So now, for the question/concerns related to the chimney height/design. The location we plan to install the fireplace is not 100% ideal as it is not directly in the center of the house and as such the chimney will not exit the attic at its highest point. After a good bit of research online, I felt pretty good about our plan and understood the trade-offs in draft performance. The fireplace will be installed against an interior wall within the heated/insulated envelope of the house. The chimney will go straight up (with the possibility of one single offset pair to clear a truss) and enter into the un-insulated attic space and then protrude out of the roof. The challenge with our location is that the chimney protrusion will be offset more towards to the exterior of the house as opposed to the very center (highest roof point). Also to maintain proper min. chimney lengths as well as the 10ft-2ft rule, we will need approximately 6.5-7.5ft of chimney extending above the roof protrusion.
When I discussed this location/plan with the fireplace shop they seemed to imply that this location was terrible and that the chimney protrusion above the roof was WAY too tall and that a chase would 100% be required on the roof and even then, it would probably smoke a ton inside due to poor draft. Unfortunately there is no other location for this fireplace that makes sense in our living room, so picking a more central location isn't really a possibility. I also would prefer to avoid constructing a roof mounted chase as it will add good bit of additional cost to the project and isn't needed for aesthetics as the chimney will be on the backside of the house and not visible from the street or front of the home. If it matters, I also plan to duct an outside air intake kit to help supply the firebox with air and improve draft.
I have attached a simple graphic (drawn to scale) highlighting the details of my planned chimney layout/dimensions. Do you hearth.com experts see any significant concerns? There are no vaulted ceilings to contend with, the chimney leaves the insulated home envelope at the highest point, the only real issue is the rather long portion of chimney "exposed" above the roof surface. Will 6-7ft of "unprotected chimney ruin my draft?
![First Fireplace - Chimney Design Question. First Fireplace - Chimney Design Question.](https://www.hearth.com/talk/data/attachments/245/245909-2a1cb2dc824f9b60cf2e54631044ad61.jpg)
