I got a new pellet stove in April and have been waiting to try It out. Well today Is the day. I came home at 4:00 and the house was 65Deg. I had already loaded a bag In so I turned the dial to on. After a few seconds I heard a clankity- clank . It was the auger pulling pellets into the burn pot. In about 30 seconds some smoke started to come up and the pellets started to glow red. Then FIRE . It got bigger and stronger and after a minute or two the room blower came on.Blowing full force. 15 Minutes later the room reached 75 Deg. which I had set on the stove. The Fire dropped back to a small burn and the room blower also went into low speed and has remained there for the last 3 and 1/2 hours. What I am saying Is the Harman Advance Is working as advertised The Instructions given to me by Home and Hearth in Hamton Falls N.H. were correct. The Addition of the O.A.K. recommended by so many of you good people on this forum Was Correct . And the use of Okanagan pellets (No dirt, Glass Is clean ) was also correct YIPPEE IT WORKS
Thanks All if you for the help
