After having all the problems I did last year, I spent time over the summer making sure everything was good to go as much as possible.
I replaced the gasket around the griddle. Cleaned out the ash pan and burn chamber. Swept the chimney/pipe. Also stacked and put a tarp over my wood. Not only stacked but did the alternating rows method where you turn them 90degrees every other row to allow more air flow. But I digress...
I just started it about an hour ago. Took a single match to get going. It was great!!
And it got hot right away as soon as the chimney heated up.
However, I've been keeping a close eye on it and a few minutes ago I noticed a VERY faint puff of smoke blow out of the elbow and griddle. My hunch is that, because I forgot to take a needle and empty/clean the 5 little holes on the rear surface of the burn chamber, maybe that's preventing proper air flow in the stove itself and allowing things to build up. But it doesn't explain the puff coming out of the elbow.
Now this is the first burn. So it's still warm enough outside that we wouldn't freeze to death by shutting it down for a day or two...I was planning it anyway. But what are some thoughts on what I'm seeing??
My plan is to let this load burn out. Then tonight or tomorrow morning I'll take a look in the thimble (which, again was super clean!)...maybe the summer heat melted some excess and caused some sort of disk/blockage...does that happen?
EDIT: By the way, since noticing the puffs I've kept the flue open and it seems to be ok.
Thanks
-Emt1581
Thanks
-Emt1581
