Hello,
I had been thinking of installing a wood stove in my basement because of the seemingly endless ash trees I cut and sell off my property every year. The cost was just too much, even with free firewood. I was looking at more than 20' of outside pipe, not including what I would have to run down to the basement. It wouldn't have been worth it.
I was turned on to pellet stoves shortly after, did some quick homework and got a pp130 and the Selkirk vp pipe all at Menard's on the last day of their 11% off sale.
I installed everything yesterday and had my first burn.
![First burn and a few questions First burn and a few questions](https://www.hearth.com/talk/data/attachments/222/222417-2b75a97533a387c012719e1bc2119386.jpg)
I burned Easy Heat pellets from Family Farm and Home. $165 a ton (I only got three bags so I can test them out, although I'm not positive what I am looking for.) I also picked up a bag of Somerset at Menards. ($185 a ton) I'm burning the Somersets today.
These pics were after yesterday's Easy Heat burn.
![First burn and a few questions First burn and a few questions](https://www.hearth.com/talk/data/attachments/222/222419-0ae4c91f24ea477adbf2e543d2a31e7b.jpg)
Is this much ash inside the firebox and on the glass normal? I burned an entire bag. I burned it on the high setting to try to heat my basement and help out the rest of the house. My geo heat is a little on the fritz, had some problems with it this weekend. The extra pellet heat helped out. I have a 1500 sq ft basement that I plan on finishing, it will be smaller than that when it is finished. I have a 2400 sq ft house. I can adjust my continuous fan setting on my geo furnace to ramp it up when I'm burning pellets. I have air returns in the basement and the warm air gets pushed around the house. I kicked off the geo last night when the house thermostat reached 68 degrees F. It held at that temperature for several hours with just the pellet stove running. Impressive but it was a balmy 34 degrees outside, we'll see how things go this week when it gets cold.
Anyway a few questions:
Easy Heat vs Somerset. Any favorites? I see a lot of good things about Somerset. The $20 difference per ton isn't a big deal if the Somersets are better.
I have a slight leak in my elbow before the pipe (4") exits the basement. It got knocked around a bit when I was putting everything together, I should have been more careful. It's not leaking at the joint, but around the 90 where the metal seams are. It is not an adjustable 90, just a standard one. I noticed a little smoke coming off it upon ignition yesterday. I put chimney caulk (2000 degree) on the seams right away. When I fired it up this morning there was still a tiny bit of smoke, so little I wouldn't have noticed it if I wasn't looking. What's the best way to remedy this problem short of replacing the elbow. I don't care how it looks, it will be hidden when I finish out the basement.
I'm new at this pellet thing, but I understand the maintenance involved. I have my carbon monoxide detector hooked up. I plan on buying a ton of pellets this week when I decide what I want. I think the only other store in my area that sells pellets is TSC, but I haven't priced them.
Does anyone tape their joints with foil tape? If so, what is a good brand. I have a joint that is inside my thimble at the basement window. I thought of taping it for peace of mind since its the only joint I really won't be able to see.
So far the experience has been good, I'm impressed how much heat the pp130 puts out. It heated my basement from 58 degrees to 68 degrees in two or three hours. Impressive when all the concrete walls are cold and bare. I'll get driven out of there when I insulate the walls and finish it.
Any help with my questions will be helpful.
Thanks.
![First burn and a few questions First burn and a few questions](https://www.hearth.com/talk/data/attachments/222/222418-ce60f07023a565ed2cf9541764011b1e.jpg)
Thanks.
