All,
As this storage method seems largely unknown here, I'd like to introduce it. It's really cheap and dries wood perfectly.
You just need a sheet of construction remesh (heavy duty, size can vary but I used 8*20'), some nylon rope and a tarp. The remesh is rolled into a tube and tied close with the rope, overlapping one segment You can add wood to it whenever you want, as you can see in the picture the upper half is newer wood. No need to stack it, just toss it in.
When you want to retrieve some, you cut a door into the lower part of it, bend the remesh open, and take the wood out. That is best done where the mesh is joined.
If there are any questions, feel free to ask.
A silo of this size holds about 2 full cords, maybe a little bit less because it is not stacked.
