Hello! I recently moved into a new home and am hoping to get the wood burning fireplace in useable shape. The home was built in the 1920s - 1930s and has the original chimney. Based on the attached photos, I’m curious if the group thinks this chimney is useable with a cleaning/inspection of the liner and parging the smoke chamber? A few things to note below:
![Fireplace Useable with Parging? Fireplace Useable with Parging?](https://www.hearth.com/talk/data/attachments/324/324004-8d88ade75c92b97c0be933ab8f49c1bd.jpg)
- I do realize that a stainless steel liner would be more efficient and up to modern standards, but if the current liner is cleaned and inspected, is it possibly useable? Trying to be cost conscious for now.
- In the bottom left of the second image you can see the flue from the basement hot water heater also running up the chimney. Would it be sufficient to parge over that for heat protection?
- The chimney currently does not have a damper, which I’m alright with for now.
![Fireplace Useable with Parging? Fireplace Useable with Parging?](https://www.hearth.com/talk/data/attachments/324/324002-a3e85bf45f9b3e924fa125780e5bc7c4.jpg)
![Fireplace Useable with Parging? Fireplace Useable with Parging?](https://www.hearth.com/talk/data/attachments/324/324003-dad4701fabce31dbd582712952ee4021.jpg)
