opening is 1066 sq. inches. The top mount damper opening is 144 sq inches, and the run is about 18 ft from hearth to cap. According to several sites this more than meets the suggested 1/10 rule for proper ventilation.
My issue is still a slight down draft. The original flu is an 18" round. At some point somebody set some steel screen atop the flu and then placed a 12" top mount damper on top of that. Could this be the reason I'm getting smoke in my house? Because the new top mount damper is choking off the the very top of the flu? According to the numbers above my new flu opening is a little over 1/7th, which, in theory, should draw air fine.
Any feedback/suggestions would be greatly appreciated, Because I was just quoted over $850 for a new 18" rectangular top mount damper with a custom fabricated round fitting to attach to my round flu.
Thank you!
Link Removed The fireplace
Thank you!
