Fireplace insert in a heatilator pre fab fireplace
McQueen
2
TN
I have a heatilator model NA42, I would like to get a fireplace insert to go in it, if this is possible. Could anyone give me any feedback on this?
It can be done. Take the measurements of the opening...Height, width & depth & go to your local hearthshop. You will need to have an insulated SS liner dropped down your existing flue,. You may have to remove the refractories if the insert is tight. Regency also makes a Heart Heater which can be installed in FRONT of your ZC box...
Reactions: etiger2007
Can it be done with my existing flue? When I installed my unit the flue had to be off set coming off the top of the firebox, so I can't slide a SS liner the full length of my flue.
