1. I have a Lopi Answer insert. I get the feeling that I burn more wood than I should be. It's in an exterior masonry chimney; and I suspect that I'm losing a lot of heat out the brick to the great outdoors. I sort of remember someone here talking about wrapping the insert in insulation (ceramic wool) or insulating the interior of the chimney. Has anyone actually done this? Did it seem to help?
2. The flue draws fine (6" SS liner all the way to the stove, with block off plate), but I'd like to insulate it to keep it clean. I've read on UK (British) hearth forums about pouring in vermiculite or something like it. I've seen vermiculite loaded cements for sale on the web. Does anyone have experience with pouring loose vermiculite/perlite around the liner from the block-off plate up? Or is a wet cement the better option?
3. are there any cat inserts currently made other than the WinterWarm or the Blaze King Princess?
How do I like the Answer? - Its fine as long as you keep throwing wood into it every 2-3 hours. Longest burn ever was 6-7 hours after cramming the firebox completely full (there's my clean flue, I know, but I'd like to sleep thru the night at least once a winter). On the other hand, relights in the morning are generally easy - especially with some ash in the bottom of the stove. The blower must be used.
Thanks
Thanks
