I had to replace the handle on my Travis Xtrordinair fireplace. Problem is, I cant get the new bolt to thread into the new handle. The bolt came with the handle in a brand new, unopened, factory sealed box. My concern is, if I try to force it to thread too much, I may strip the threads (which is what happened on the old handle). The new threads on the handle are not stripped; they look perfect.
Do you think the threaded piece is thick enough to drill a small hole and put in a cotter pin? Im not sure if doing so would remove too much material around the hole and compromise the strength of the handle.
Thoughts?
Thoughts?
