fireplace blower
9
Yardley, PA
I am looking into some sort of fireplace blower. I don't have the budget for a stove or insert. I came across "The Original Grate Heater". Does anyone know if this works well? Or can you recommend something similar? What is the best product/company for this type of unit?
There are a NUMBER of companies who make Grate Heaters & all of them claim to be better than sliced bread.
The hearth shop I used to work for offered the Stoll Version ( (broken link removed to http://www.stollfireplace.com/heating/GrateHeater) )
& I don't recall too many going out the door. The MAIN problem with this unit is that in order to get ANY appreciable
heat from it, you need to keep the fireplace doors closed. Otherwise you'll lose most of the generated heat right up the chimney.
In order to close the doors, they need to have PyroCeram stove glass in them instead of tempered glass. That jumps the price WAY up.
Tempered glass won't take the heat & has a tendency to shatter when it gets overheated.
Probably not the info you wanted, but that's the way it is.
