I understand that firebrick are used to line wood stove. Has anyone use it in their pellet stove? Good idea or not?
Mine came with firebrick
Mine too, 3 across the back but I have wondered why you couldn't put them on the sides to retain heat.
I've only ever seen pellet stoves with ornamental bricks, not true heat-retaining fire bricks like in a wood stove. The biggest difference between a wood stove and pellet stove is that in a pellet stove you do not want to "retain" heat." The objectve is to transition the heat from the inside of the stove into the living space of your house without shooting too much of the heat out the vent pipe. True firebrick, I would assume, would be counter productive to the cause. Am I off course here?Mine too, 3 across the back but I have wondered why you couldn't put them on the sides to retain heat.
The 3 in mine are true fire brick, I would assume to keep heat away from the back of the stove
