Firebox Corrosion Analysis with Pictures
So I happened to be in my boiler building today with some extra time.
Took a picture of the inside of the burning chamber
And one of my hand after rubbing the roof of the chamber
Then I tried to clean around one of the stays. No sign of any moisture. It was hard caked on creosote
I chipped it off around the stay and cleaned the weld as good as I could.
I feel that by the appearance of the weld and surrounding metal that my boiler is experiencing zero corrosion on the fire box side of the metal
I don’t know anyone with an ultrasonic measuring device to prove me wrong.
It’s been a couple weeks since my last fire and the boiler temp is below 70F as that is as low as the gauge goes and the needle is sitting on the peg
[Hearth.com] Firebox Corrosion Analysis with Pictures
I don't really know guys, maybe its just chitty places in the steel, a lot, like 95% of the hotroll we get is recycle anymore so you never know. the one I fixed had about an 18 inch square area at the back that was ate up, not totally but I went out that far to be sure and get into good metal, otherwise I could not find any thin areas, when I had the chunk out I used the old finger caliper method and could find no thin areas, not super scientific but I do auto body work and can feel fairly accurate
The inside of my Tarm MB 55 always looks like that -- hard and flaked creosote. It has for 46 years. I installed it in 1980 and have heated my home every winter with wood. I have never had any corrosion of the steel. Creosote is very corrosive if there is moisture/condensation. Every year, after I am done burning for the season, I put a10"X12" aluminum plate inside the MB 55. I have a 60 Watt surface mount resistor fastened to the plate. The plate/resistor will increase the boiler water temp 5 degrees above the ambient temperature. This ensures the steel boiler walls will always be above the dewpoint and the steel walls will never have any moisture on them.
It must be out dry climate up here
The first few years of having my system going i would check to see if there were any signs of moisture, as i would always read about things people did to their units over the off season
It's always been the same caked on hard dry creosote.
I actually am very happy with my Econoburn being basically bulletproof, it can use a few improvements.
Had i not found Hearth, and gone with my original plans i would have had a subpar system with crap lines that would have made winters unbearable.
Thank You everyone who posts their experiences, winter heating for me is systematically boring.
