For some reason, I'm having more trouble starting fires in my Winterwarm this year than in all the previous 24 years we've used it. I have some StarterLogg brand fire starters. My wife says they will mess up the catalytic converter. Is this true?
I know that super cedar firestarters are the best ive used and they are safe for the converter. I use a 1/4 of a puck if i am cold starting the stove and they have never failed. You can order them from super cedar website and i believe if you enter the code "hearth 20" in your purchase order you get 40% off i believe. As for the starter logg brand i have never used and i cant see from their website any info regarding use with catalytic converters. Im sure somone who uses them will chime in.
Are you using a whole starter log? If so there is a problem with your wood or stove. I use the match light starter sticks and only use 1/2 of one. If it's just the small starter the it will burn up before you close the bypass.
A few things could be a bit different than it was.
The draft is a big issue. everything from week draft, to the chimney cap being so plugged smoke is backing out the stove door. Keep the door cracked until the stove is rippin.
The wood, hard to light wet stuff.
The wood stack, A lot of log cabin stacking with open air space works.
And last but not least, is a brain fart, where you can't exactly remember how you were doing this last year.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
