fire goes to right
Jimrig
24
JUST clean my two englander 25 pdv. now on the one the fire goes to the right as you look at the front of stove.any idea?? maybe Mike will jump in here. Glad i fround this forum. jim
Looking into the stove through the glass, the bottom auger rotates counter-clockwise. This motion pushes the pellets to the right side of the burn plate. Maybe this is the answer?
did not do it before i clean it. plus the other stove is not doing it. jim
Guess #2: Maybe the entire burn pot assembly is not level?
What is the hole pattern in your burn pot. The bottom row in my harmon is offset to one side
I have a quadra fire and mine does the same thing now. Fire and ash buildup is always to the right.
stoveguy2esw said:
check the cleanout behind the baffle plate , when they get backed up that can happen
Huh? :bug:
Thank's i clean it again .this time i took a coil spring that they use to bend copper tubeing with has a flare on one end tape the spring with black tape it fit's right into the end of the tool on my vac hose.i can flex it into that opening behind the baffle plate both way's.dose a good job. JIM
usmcdogg;
ash buildup migrates to the right due to exhaust fan location....I also have a quad...
thank's i have these two stove for four yr's now.never had that before .repeated the clean out work's o.k .now
staplebox said:
Mine always hangs to the right. Me and the stove.
Hmmm...possible PhD thesis fodder.....? Do right-handed guys hand to the right, and left-handed's to the left? Any correlation there, I wonder?
My flame leans to the right, as do I.
