You guys helped me select the drolet spark ii. Ran the Duravent chimney . The 2 30 degrees worked out perfectly to get around the soffit. It’s 30” over the roof top. The chimney cap feels very loose. I push and push and that’s all it’s got. Guess I’ll find out if it’s on first wind storm. Instructions for the install and on line videos are meh. I struggled with the bracket - felt like I needed 3 hands. I’m a plumber by trade and I found it challenging. Inside I used single wall and put the stove 19” off the rough wall. The drolet manual didn’t tell me the distance. I had to research on line and saw 18” to flammables. After it’s insulated I’ll probably put a sheet of cement board behind it.
Tomorrow I start my first fire. Manual says medium heat for 4 hours break in. I’m planning on keeping it 400-500 degrees or less.
See anything wrong w my install?
