I've learned a lot about this stove so far this season, and my major complaint, short burn times, I've been able to fix (7.5 hours or so, but will get up and check it at 3 tonight it being 2 degrees).
My less major complaint I have not fixed - creosote. The good news here is that I just clean the stove pipe monthly, so it's not that horrible of a thing, except I think it's fixable, I just need some help.
I finally bought an insert thermometer for the flue, and watching it tonight, it will go up to 400 or so when the air supply fan is on. When the air supply goes off, the flue temp drops to about 200 (thus the creosote), back up, back down.
Door air supply is opened 2 turns, so should be getting a decent draft. Barometric damper is set right, in fact even if I shut it down most of the way, I still have this issue.
Stove is 600 or so (measured above the door by 2 thermometers).
This may be the biggest clue - I do get smoke coming back out the door air supply at times, especially if I open the air supply fan all the way.
Stove pipe - out from the stove, straight up, double wall up to ceiling, 6' of pipe, triple wall from there 10' more, 4 feet of that outside. No top to plug up, has a rain cover but not a spark arrester. I do have trees close to the house that may be causing some downdraft.
Do I need to just add 4' of pipe to the top? Or?
