finally bit the bullet, realized how unsafe that 1261 really is
ad356
156
north java, ny
I bought a stove today. I bought a US stove country hearth 2000. at $600 the price was right and tractor supply is only 20 minutes away. my neighbor who does construction has a job he had to finish today. I went over to see if I could use his truck. he told me the job he was working on was only 5 minutes from TSC and I could go with him and pick up a stove. I will say I am not disappointed, what a nice unit for $600, I don't understand why people buy lopi, Harman, and Avalon for $3,000 when you can have one of these or an Englander for $6-700. I did not like my 5510 but this unit seems to be decent. there is a larger diifferencee between a Harman pellet stove and a cheaper unit, with wood stoves the differences are allot less noticeable I noticed that it had good reviews on this site so I decided to go with it. there was also another customer at TSC that said he has had one for 12 years and he's extremely pleased with it, being the only repair he has done in 12 years is new firebrick. I had a smaller fire and it still put out fantasic heat. I wanted to keep the temps down as per manual, says to avoid running it hard until paint has cured. I hope to have this great unit 20 years or longer.
with an EPA stove what should I set the draft control at? I had it cracked open a little to keep the heat in the stove but let the smoke out, is that correct?
as far as the 1261 goes it should be removed from the market as per being a very unsafe unit. running a modern stove I realize just how much safer they have become. the 1261 is impossible to control, draws flame up into the black pipe, makes the chimney much hotter, eats firewood like there is no tomorrow. how old is that design anyways? its terribly unsafe. im going to try to sell it but I probably lost my money on that piece of junk ($60 if I cant get it back oh well, lessons learned). I ran that modern stove and the chimney was warm to the touch, not hot. I never got it up to glowing temps with that 1261, I would never let it get that hot, but it was hotter then I would have liked it to be. I would rate this stove as an old, outdated, unsafe piece of junk. belongs in a museum then on the store shelves. the sad part is people still buy these things new. I noticed that the modern stove has fire proof material on the top of the firebox preventing flames from being sucked into the black pipe the 1261 has nothing to prevent this.
The idea with burning non-catalytic EPA stoves is that you keep the firebox hot enough that the smoke burns. I close down my draft as much as I can once I get the firebox hot.
I suppose people buy more expensive stoves because they have features that the Englanders and US stoves, etc. do not. Sort of like the same reason people buy Cadillacs when a Chevrolet will work.
Matt
Reactions: BurningBrutus
For folks that may not know what the US Stove 1261 is:
[Hearth.com] finally bit the bullet, realized how unsafe that 1261 really is
Reactions: n3pro
I know there are good older pre-epa stoves but the 1261 is not one of them. its an unsafe design. I decided after using it several times that while it did produce SOME heat, it seemed dangerous, I don't think I could work in my barn knowing that thing has a fire inside of it. didn't seem like a safe unit to be having a fire in, especially being that the firebox isn't sealed. another good point im going to make is that when you close the draft to burn the smoke inside the stove since the unit is not sealed it has a tendency to leak smoking into the building.. I quit smoking cigarettes, lol. I don't plan on starting up again.
I don't understand how a company called United States Stove Co. Sells stoves made in China. Personally I'd rather spend the extra money to buy American made.
Congrats on upgrading from the box stove. Those scare me too!
I bought Lopi for a few reasons.
#1 I hadn't found Hearth.com yet and didn't know about Englander, Woodstock and BK (the only three others I might have considered stoves from for various reasons). HOWEVER
#2 The Republic 1750 (and the sister stoves from Avalon and the Endeavor) is one of very few stoves that can have a 4" rear clearance and has ember only hearthpad protection-space in a 700 sw ft house is a premium item
#3 We didn't feel confident enough to do an install ourselves and weren't sure how to find someone outside of a hearth shop that could
#4 We had two Lopi DV stoves, one for about 13 years and one for about 10, that we were very happy with-stick with what you know.
#5 I loved the style of the Endeavor (settled on the Republic after getting the cost for the flue though, since it was less $$ than the Endeavor)
#6 It's made in America. I don't want a Chinese made stove in my house. I want more quality control than what I've come to expect from "Made in China" when it comes to something that holds FIRE when given a choice. I plan to keep it a long time so I wanted to go with something I felt I could trust. (along those lines I also don't have a new kitchen range, I use one built like a tank in the 1950's by Floyd Wells).
I know that the stove I bought was made in china, but it does seem to be fairly well made. we will see how I like it over time. it fit my budget requirements, was easy to go pick it up (tractor supply was 10 minutes away), and this is not going in my home but my barn. I already had a fire in it, after running it I would not have minded it if it was in my house. seems like a very nice unit, especially for 600 bucks.
It isn't that bad of a stove, but after carrying my brother in laws into his house there is a big difference in quality between his and my Oslo! Fit and finish and weight was a big difference among many other things. Like you said though his stove was almost $2000 cheaper!
There is a HUGE difference between a Chinese stove and the ones that you mentioned! The fact is, you make a fire in any old metal box, it will get hot. The difference is in the build quality, durability, style, and the fact that it is made by American craftsman. I'm glad that it is doing what you want, making heat for a low price.
I can't imagine runnning one of those box stoves in my house! I'm glad to see you got rid of it. Scary!!!!
I never ran that box stove in my house, I didn't even feel safe working in the barn with it on; plus I would spend more time fiddling around with trying to keep a hot fire then I would actually doing anything else. it also would have chewed through my 2 chords of fire wood and the scrap wood that I have collected way to quickly. I think that box stove would have put more heat out the chimney then into the room. terrible design, only safe burning it in the middle of your back yard to burn trash, lol. glad its gone. now i will have safe as long as im smart about it don't pour gasoline on the stove, duh (common sense there). the us stove 2000 isn't as heavy as some of the better stoves im sure but its heavy enough; i'll have to report back after running it for a while, but its not an ornate or designer type of stove but it seems to built well enough to last a long time. when we moved into the house there was an old US stove circulator in the living room, the previous owners had constantly overfired, all of the firebrick were cracked but the stove was still in fairly good condition. if i had kept it i probably still could have used that in the barn but that was 3 years ago and i had junked it a while ago. the thing was probably 20 years old if not more. it was a circulator that had a glass window in it, i don't think they have made that in a while. for the $600 i don't think you can go wrong and if i have it 20 years i will be beyond pleased.
as far as what i use in my house, its a Harman P61; less fuss for the wife. i can load it up with pellets before i go to work; 14 hours when i come home its still running at the same temperature it was when i left it. i also have a thermostat to regulate the temperature so the wife can adjust it. my Harman was $2800. i hope to have both stoves for a very long time.
My neighbor has heated his shop, which is two stories and bigger than his house, with one of the box stoves for years. But it only runs when he is in the shop and close too it. The house is heated with a Harman insert.
