I need ~40' of 3/4" fin tube as a heat dump for my Tarm Solo 60. I have a 4' vertical rise from the Tarm to the ceiling and the pipe can run 12' along the ceiling of my shed roof that is a 4/12 pitch.
Two questions:
What is the best way to plumb the heat dump...should it be one 40' loop (12' up ceiling, 8' across (level),12' down and 8' across (level) or would it be better to run it 4' up, use a manifold to split it into four 10' runs going up the sloped ceiling to a return manifold and down to the boiler?
How do I make a non-45*, non-90* bend in 3/4" copper to go from a vertical pipe to follow the sloped ceiling. I thought about using two 90* elbows but this seems less than ideal since it seems like this would limit gravity flow in the loop.
Thanks for your advice!
DC
Two questions:
DC
