Feed Auger not working
Tyler G
7
Eastern MT
I have a Whitfield Optima 3. When I turn on the stove the auger makes a quarter turn and then quits. I have taken apart the motor from the auger. I removed the auger and cleaned out the shaft. The auger moves freely in the shaft. I also had older motor that I replaced a couple of years ago, that worked when I replaced. It is doing the same thing makes a quarter turn and then quits. I have also have the motor disconnected from the auger and still not working. Any suggestions on what to look at next. Thanks, Tyler
Possible failure to activate vacuum switch? Not enough umph in the combustion fan or bad gaskets or blockage in venting or blockage of the vacuum tubing from the burn chamber to the switch.
Reactions: Delta-T
Better get on it, I see some snow in your future!
