That may be true but it does not make that video any more true.Don't know about the US, but my friends in London can only burn coal, not wood
I wouldn't say so much the feds but local areas are getting more strict every day.
Well saidwell i can see why tbh, i css to get ahead for at least a year so my wood is seasoned and dry and my neighbor right across the road has his load of logs dropped off around the beginning of october, that's what he burns this year in his outside wood boiler. On a damp cold morning that thing makes the area look like a fog bank has rolled in off the ocean. I know more than a few of my fellow neighbors have petitioned the town board about, and i honestly cant blame them. the sad thing is all it takes is one individual like this to give those of us that try to burn clean and reap the rewards from wood heat a bad name. . .
It is not carbon neutral at all. It is better than many other forms of heat in that respect but absolutely not carbon neutral. Even if it was carbon neutral that does not mean it does not produce pollution. That is a totally different issue.Wood is carbon neutral so if the argument is pollution they have no leg to stand on. Insurance on the other hand I could see an angle.
I take the carbon out of the woods, refine it in my BK Carbon Extractor, then scatter it on my garden and lawn.
Not sure if that's neutral or not, but the carbon doesn't seem to mind!
But again this video is total bs no truth to it at all.
Like I said better than most other forms of heat but not carbon neutral.My understanding is that the act of burning wood, in and of itself, can be carbon neutral, provided the area the tree was taken from is to remain forested. If so, new trees replace the ones burned and reabsorb the carbon. And if a tree is removed, it will release carbon when it decomposes regardless if that's via fire or rotting.
Collecting and processing firewood is what makes the process not carbon neutral.
The EPA last year made its first woodstove reg change since 1988. More local areas are adopting OR and WA state regs to mitigate local or regional pollution. In some cases the local regs are much more strict and there's been some pushback, like in Utah.I wouldn't say so much the feds but local areas are getting more strict every day.
Kinda splitting hairs......Like I said better than most other forms of heat but not carbon neutral.
No not at all. It is either carbon neutral or it is not. And the whole process of burning wood for heat in your home is not carbon neutral. I didnt say that was a good thing or a bad thing but it is a fact. And being carbon neutral does not mean it is free of pollution anyway.Kinda splitting hairs......
If you use no power tools then it would be carbon neutral?No not at all. It is either carbon neutral or it is not. And the whole process of burning wood for heat in your home is not carbon neutral. I didnt say that was a good thing or a bad thing but it is a fact. And being carbon neutral does not mean it is free of pollution anyway.
Some say yes some say no. I think it would be close enough to neutral for me to call it that.If you use no power tools then it would be carbon neutral?
Might depend on what you ate for lunchIf you use no power tools then it would be carbon neutral?
There's exhaust one way or another!Might depend on what you ate for lunch![]()
