Sorry if this has been discussed before...
So as I'm getting prepared to do some Taxes in the not so distant future I'm looking at energystar.gov and come across the frequently asked questions
Whats up with this?? Can I not install my own stove? :roll: Or is the "strongly recommended" just suggestive?
I’ve been told I can’t get a rebate for a cleaner-burning wood stove if I install the stove myself. Why can’t I install my own stove and save the installation expense?
EPA strongly recommends that a certified technician install your EPA-certified wood stove or fireplace insert to insure proper performance. First, the safety of your home and family depends on a full understanding of the manufacturer and building code requirements. Any errors in installation (by a non-professional) may not be visible, and problems may not be apparent for a considerable length of time — and some could result in a home fire.
Second, proper functioning of the venting system (a.k.a. the chimney) is the key to efficient, cleaner wood-burning. The venting system is the “engine” that drives the burning process; if it does not provide adequate draft, your stove will perform poorly or fail. A stove and venting system that is properly sized and installed will require less wood, produce more usable heat, and reduce maintenance from inefficient fires.
http://www.energystar.gov/index.cfm?c=tax_credits.tx_index
Thank you,Hiram
Thank you,Hiram
