Hi Gas Burners,
I thought that I would give you all an update,(epecially Dasky & JTP), on my replacement FB Grand Insert that I was scheduled to be installed by the dealer today.
To refresh your memories, just a bit, this replacement unit was to change out my current unit that had a terrible metal exspansion noise,(Loud Bang), when the unit heated up and activated the snap switch for the blower after approxiamately one minute of fan operation.
Hearth & Home tried to correct this problem by installing angle strips of metal,(three on each side and two in the back of the unit) to take the Excessive SLOP out of the sheet metal shroud that surrounds the ceramic firebrick firebox that channels the air from the blower.
As mentioned in an earlier post, this attempted fix failed and failed badly. After this attempted fix the sheet metal bangs louder and even does it when the blower is shut off. It was so bad the last time I had the blower on and it made the banging noise, I had to go into the garage and retrieve a putty knife to peel our siameese cat off the ceiling. As soon as I got the cat off the ceiling, our dinner guest asked , in order of need, if they could use our bathroom to clean their soiled underware.
Needless to say, I did not operate my insert when the cat was anywhere in the room or I had dinner guest/company at the house.
Here is "the icing on the cake". The two dealer installers arrived at the house to swap the units out. The unit they brought with them, was pulled from the dealers inventory,(Penna.), and sent to Hearth & Homes plant in Minesota. At the plant, it was unpacked, pre fired, and inspected by the Product Service Manager for correct fit of the sheet metal shroud and also given a general visual inspection for visual defects.
After this process was completed, it was repackaged and sent back to the Penna. Dealer for todays install.
The two dealer technicians and I rermoved the bi fold door glass front from the existing unit and were ready to start the removal of my existing unit. The two technicians went outside to their van to bring the new insert into the house. After removing the glass front from the new insert, the technician told me that I better take a look at something on the new insert. The paint on the back and the two sides of the firebox was just about all removed exposing the white ceramic firebox.
Some IDIOT at Hearth & Home wrapped the ceramic fiber fire logs into almost a ball and used shrink wrap to keep them together. This wasn't bad enough but than they took the shrink wrapped logs and stuck them onto the grate in the firebox with one piece of padding between them and the painted firebox. Needless to say, the "IDIOT",(I believe I know who this IDIOT is), shipped the unit this way and the vibrations removed basically all the paint off the firebox onto the pad. Normally, these logs are packed seperately sandwitched between two pieces of egg crate shaped foam for shipping to keep these VERY Fragile logs from being damaged.
The dealer could not believe this but the H&H;Product Service Manager, when called by the dealer, gave me a ear full of attitude.
Can you believe this???
Is Heat & Glow going down the crapper or what? Do they have any idea of what quality control is, or let me rephrase that question, do they even have a quality control dept.?
I truly believe that they are ready to go "Belly Up" and they truly don't give a sh-t anymore.
I can't believe this is happening to me![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
PLEASE, GOD ALMIGHTY, GIVE ME STRENGHT
John
John
