Hi All,
I'm new... so I'm open to this being operator error.
I have an Englander 25-PDV. It's great! Except, after 6-7 hours of running...and every single night... the upper auger stops feeding pellets. I've called England (great tech crew!) and we decided that it had to be the vacuum switch. They're in the process of sending me a new one, but at the moment, the switch is by-passed.
When I woke up this morning, the fire was off...but there were 10 or so unburned, untouched, pellets in the burn pot. I restarted the unit (had to jiggle the auger motor a bit...but pellets flowed great after that). One more time through out the day it died, but I just quickly jiggle the upper auger motor, and it worked great again. I figured a pellet or two got stuck.
To my exasperation, the upper auger stopping occurred again tonight. It's been running all day, with a few issues, but mostly running. I waited it out...and as soon as the machine was cold, it started again. My room is not all that warm, I'm running the stove on settings 4 and 6, so the fan should be pulling most of the hot air out from the unit.
I've only had the unit for 3 weeks...but did clean it out completely this weekend in hopes of finding a stuck pellet or some such thing.
Any thoughts? Maybe it's just pellets continually getting stuck and then they happen to work their way out when the unit gets cold?
Oh, so far--I've realigned augers (but am willing to say I maybe did it wrong?); switched the auger motors; tried 6 different types of pellets. The stopping is much less frequent now... it use to only run 20 minutes or so in the beginning. I'm on the road to finding whatever will fix it!
I'm a tinkerer....so none of this is at all phasing me yet. (It stopping during a negative degree night...and I'll have some choice words)
Thank you for your help!
