Fan on high all the time
mactoolsix
8
Saratoga, CA
We have had a Quadra-Fire Castile Pellet Insert for about nine years with very little problems. This last summer I pulled it out for a through cleaning and all new gaskets - first time! We use it only 4-5 months a year for a few hours late evening.
It has been working fine, but suddenly the fan only runs on high - except during start-up when the fan speed can be changed. But once it lights, it's high full time all the time. I pulled the rocker switch out, but as expected it seems to test normal - center pole to either side is on or off depending on the switch position. When on medium, no continuity to either pole.
The schematic provided with the instruction book is very basic and does not provide a clue as to how the fan is controlled. The red call light works normal; the flame is active and adjustable with the Fuel Adjustment Rod; it lights within a few minutes and all seems normal. It would be better if we could turn down the fan speed.
Bump
Does anyone have a schematic of the switch - 3 terminals. Center connects with either outside terminals in high or low. Med has no continuity to either. Is this correct? I'm beginning to thing maybe it's the switch afterall???
Thanks,
Mike
Many stoves have a snap disk that bumps the convection fan to full speed, usually at 160 degrees. Pull one connector off that snap disk and see if control returns to normal. If it does, replace the snap disk. This video might help.
