To move heat from the woodstove I am experimenting with fan placement. Tried a pedestal fan behind the corner located woodstove for latest trial .
Even on low speed the probe temp Guage drops substantially shortly after fan is turned on . Fan essentially is pointed at flue on opposite side of Guage.
Could I actually be cooling done the flue gas in a double wall pipe that much or is it just the magnetic probe exterior the fan is affecting ?
Will post a picture later if it helps explain .
