I found a used non pro 026 for sale in good shape for $250. I'm not sure if that's a fair price. I was thinking about offering $200. The bar looks like is a non pro bar and looks to be almost shot. Thoughts?
I looked at the saw yesterday and decided to pass on it. It seemed to run just fine other then when it was at idle the chain would run a little and the oiler was working fine but the compression came in at 120pounds. BummerGreat link - thanks
One thing I forgot to mention is some of the later 026's came with Wt-403b and 426a non adjustable carbs. You can set the low side but not the high. They can be swapped to a fully adjustable carb Wt199 with a little work, the carb box needs another hole for the screwdriver to reach the screw. When checking compression you must have a tester with a schrader valve in the end of the hose and keep pulling the string until it stops climbing. If that thing is only producing 120# compression it may run but not well.
They also came with two different oilers. The oiler on the pro was adjustable the other was not. The oiler is usually not a biggie as both oilers slobber oil enough to oil an 18" bar. Depending on how old, the air filters can be tough to find for reasonable $$$ (it depended on which tank vent you have) The hard ones to find have the tall tank vent. I am going to look into what it will take to switch mine over to the low vent so I can use the cheaper filters. One design feature I hate in this series is the choke is in the air filter instead of the carb body where it should be.
Where do you get the filter replacements and how can I tell which one I need? I assume it is the older more expensive filter but I want to make sure
Funny you mention the older style 026 w/ non adjustable carb Firelaker. That is exactly what I found on craigslist except the owner of the saw had changed it out so that it is adjustable. The compression was over 150 and it runs like a champ....can't beat it for $175and it came w/ 3 newer chains and a lightly used 16" bar. Very happy!
If memory serves me there is two filters for the non Intelicarb models, they put two different tank vents on them, a short round one and the earlier tall one with a grub screw.
I agree with Jon try cleaning first. The dealer may have one. They are not making the old style in aftermarket yet. If memory serves me there is two filters for the non Intelicarb models, they put two different tank vents on them, a short round one and the earlier tall one with a grub screw. The same filter was also used on the 024. Does your saw have a red or black "operator presence lever" That is the on,off, choke lever?
